TwinTurbo.NET: Nissan 300ZX forum - Just double checking -- when messing with the idle
jzack
on December 17, 2009 at 7:38 PM
before, the idle screw was threaded in pretty far, I tried
posted by LJZTT
on December 17, 2009 at 06:37 PM
screw did you also disconnect that yellow connector that goes to the (idle adjust) solenoid?
Running out of time to get Z sorted out
17:38:32 12/17/09
Re: Running out of time to get Z sorted out
WazTTed
17:57:17 12/17/09
Re:
18:33:33 12/17/09
18:37:35 12/17/09
Just double checking -- when messing with the idle -
jzack
19:38:37 12/17/09
I did not, I believe it can be turned off via Datascan tho
20:00:49 12/17/09
Just mentioning because that's the procedure for
jzack
20:50:20 12/17/09
Re: Just mentioning because that's the procedure for
22:23:13 12/17/09
Just for grins -- disconnect the TPS and then the
jzack
16:33:26 12/18/09
Re: Re:
WazTTed
20:58:22 12/17/09
Just finished running the "hunting" checklist from FSM
19:48:27 12/17/09
datalog once warmed, driven slowly around the block
19:58:44 12/17/09
Re: are your throttle plates opened? it seems you are
tognot
20:27:48 12/17/09
Throttle body butterflies...
ZTurboFan
21:37:48 12/17/09
the air leak could easily be responsible for your idle
surfer31337
20:30:36 12/17/09
how can I know if I have resolved the high idle if it wont
22:26:38 12/17/09
OK. this is EXACTLY what you should do (in this order)
surfer31337
23:19:43 12/17/09
Yeah, and I really like #1.
ZTurboFan
00:41:15 12/18/09
Re:
02:23:37 12/18/09
One thing I found
Stadsport (PHX)
20:38:16 12/17/09
@#$%ing FUEL LEAK.......puddle forming under the car
22:17:10 12/17/09
Sort of same boat.
Jehannum
12:54:28 12/18/09
RESOLVED....finally
02:00:14 12/19/09
So after you repulled and fixed the fuel leak, your
BoneZ
09:31:17 12/19/09
as luck would have it, I am back again with high idle
11:46:39 12/19/09
update: seems I have a sticky throttle that I cant figure
16:56:01 12/20/09
Re: update: seems I have a sticky throttle that I cant figure
WazTTed
18:49:08 12/20/09
yes, I said in the post it wants to stick around 2k after
19:14:02 12/20/09
